Unable to send emails. All else ok. can u help?
HELP!
Since yesterday, I cannot SEND emails. I can receive them and can access the web. When I try to send an email, the following message pops up:
" Symantec Email Proxy.
Your email message.....was unable to be sent because the connection to your mail server was interrupted. Please open your email client and resend the message from the Sent Message folder."
Can anyone help?
I had the same ptoblem yesterday (just using Outlook 2003 - Thunderbird and Outlook 2000 were still working fine !!)
Then I lost connection totally (problem with Plusnet/BT)
Once I reconnected, all mail was working fine.
Perhaps you should try disconnecting and reconnecting.
Try disabling your Norton/Symantec software and see if it then works, this includes any anti-virus and firewalls. Norton are well known for causing this kind of problems after recent updates.
Your email is going via norton (you will find norton is set as the mail address not plus net)change you setting in your mail prog so its going direct to plus net.
Norton acts as a mail server and then passes it on to plus net it often has a wobbly
