Unable to connect!
Unable to connect!
I'm having to use dial-up to post this message. Anyone else having problems with ADSL? Or is it just me?? This is the first time I've been unable to connect.
Unable to connect!
Seems a bit coincidental with PlusNet's recent maintenanceHuh
Plusnet Staff
Plusnet Staff
Unable to connect!
I notice from your profile that you are in London, there's currently a major service outage in Malden, and one earlier in Streatham. We're currently waiting the next update on the Malden problem.
BT Wholesale - Broadband Incident Report
This is to notify you of an incident, which MAY affect your end-users.
BT Reference:BBDN6382
Network Element Affected:LONDON MALDEN MUXS 101, 2 & 3 - LOSS OF SERVICE.
Dialling Code/s Affected :0208241 0208286 0208336 0208395 0208404 0208407 0208408 0208605 0208715 0208781 0208942 0208949
_____________________________________________
Start Date:18/03/04
Start Time:13:17
Anticipated Clear Date:18/03/04
Anticipated Clear Time:17:30
Progress report:
UNDER INVESTIGATION /ENGINEER ON SITE DEALING
Unable to connect!
Isn't that just typical, I live in New Malden!! Wink
Plusnet Staff
Plusnet Staff
Unable to connect!
The latest update on New Malden's just come in
Start Date:18/03/04
Start Time:13:17
Anticipated Clear Time:21:30
Progress report:
ENGINEER ON SITE, WORK BEING UNDERTAKEN. REPAIR IS TAKING LONGER THAN ANTICIPATED, BUT SHOULD BE COMPLETED WITHIN THE HOUR.
Unable to connect!
Cheesy
