Unable to access ebay from networked PC
Pulling my hair out with this one guys!!!!!
I've got my ADSL shared with a networked PC, both PC's setup exactly the same, both with ZA Pro as a firewall.
My machine, which is the ADSL host can access www.ebay.co.uk fine, however the networked machine can't, em received "document contains no data"!!! Although it can reach all other websites.
I've disabled both firewalls to see if that resolved the issue but no luck, running a tracert on the problematic PC resolves about 8 hops and stops somehwhere outside of this local network.
How can I access, yet the networked pc can'tHuh?Huh
can you reach it if you do
http://66.135.208.41/
If you can then its either the dns setting on the pc or your host file has something in it. check
C:\WINDOWS\system32\drivers\etc\hosts
the host file can be opened with notepad. If that file has somthing like
127.0.0.1 ebay.co.uk
in it this will stop it as it will look for it on the local pc, often adaware progs or simliar often change the host file.
If this doesnt fix it post the r esults of ipconfig /all from each pc.
no luck Mr Wright, hence please find below the ipconfig /all results from both pc's;
Host:
Windows IP Configuration
Host Name . . . . . . . . . . . . : russpc
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VIA Rhine II Fast Ether
Physical Address. . . . . . . . . : 00-50-2C-05-A6-D3
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Ethernet adapter PlusNet Broadband:
Description . . . . . . . . . . . : Binatone ADSL500 USB Modem Network Adapter
Physical Address. . . . . . . . . : 00-0A-E2-10-54-D6
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 80.229.148.12
Default Gateway . . . . . . . . . : 80.229.148.12
DHCP Server . . . . . . . . . . . : 192.168.1.2
DNS Servers . . . . . . . . . . . : 212.159.13.49
212.159.13.50
Lease Obtained. . . . . . . . . . : 23 August 2004 19:08:34
Lease Expires . . . . . . . . . . : 24 August 2004 07:08:34
Client:
Host Name . . . . . . . . . . . . : dadspc
IP Routing Enabled. . . . . . . . : No
Connection-specific DNS Suffix . : mshome.net
Description . . . . . . . . . . . : NVIDIA nForce MCP Networking Controller
Physical Address. . . . . . . . . : 00-50-8D-55-7C-D3
IP Address. . . . . . . . . . . . : 192.168.0.133
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
Lease Obtained. . . . . . . . . . : 23 August 2004 21:48:03
Lease Expires . . . . . . . . . . : 30 August 2004 21:48:03
I have absolutely no idea what's causing this
Hi dunlop, funnily enough I had the EXACT same problem a few months ago on my home network, with 2 XP machines, and 1 Win98 machine. And my PC (the main one) could access eBay fine whereas the others can't... very strange!
The way I fixed it was to make sure all PC's have the same MTU value as the main PC. Strange I know! But sure as heck it fixed it! :shock:
Find out how to change your MTU value here.
Hope this helps you! Smiley
