USR sureconnect USB/ethernet modem router
I am having a lot of trouble using mIRC. Has anybody got this modem and have they got it to work with mIRC? I've tried everything I can think of. I've allowed all connections in and out from and to anywhere. I even mapped all the ports to my PC for NAT. When I use dial up the connection is successful.
The firewall log and netstat shows my PC attempting to connect, but nothing comes back.
RE: USR sureconnect USB/ethernet modem router
You dont say what the problem is can you connect to mirc and recieve files but cant act as a xdc server?
This doc may help its not fro your router but may point you in the right direction as a lot of the connfig is Mirc, If you defined the problem better I may be able to help
xDSL / Cable Connection with 'SOHO' Router
Some Notes to get you past the common problems.
If you are running mIRC version below 5.7, UPGRADE to 5.9
Note 5.91 Is a script breaker
Environment:
Net Connection: Single IP Address. Cable / xDSL
Interface: LINKSYS DSL/Cable Router (BEFSR41) 1.38.5
[ Netgear etc. are very similar ]
PC's: 6 (One dedicated to mIRC)
Public IP Address: Assigned to Router
PC Addresses: Statically Allocated 192.168.x.x
General:
There are two parts to configuring mIRC for use with a NAT Firewall.
1. Configure mIRC
2. Adjust Router Configuration.
You should NEVER have to put the mIRC machine in the DMZ
Security.
Install ZoneAlarm on all windoze machines. (Free version is fine)
www.zonealarm.com
Install a good Virus Checker on all machines.
mIRC Setup: (ALT-O)
Client or Server.
Section: Connect - Local Info
On Connect Always get Check Local Host
Lookup Method Check Server
This should fill in the two boxes at the top with your
PUBLIC host name and IP address when you connect.
(DCC Sends will not work if this is your private address)
Section: Connect - Identd
Enable Identd Server Check
User Id Enter a Unique string
System Enter a Value e.g. Unix, Hybrid
Port Must be 113
Enable Only when Connecting Check
Section: Connect - Firewall
Do not use unless your firewall tells you how to do it.
Section: DCC
On Send Request Check Minimize
If Auto-get and file exists Check Resume
Section: DCC - Options
DCC Ports
First Set to 12340
Last Set to 12349
Note: Any range between 1024 and 65535 is good.
More than 10 ports is pointless, unless your connection T1/E1
Max remotely requested DCC sends Set to 7
Section: DCC - Folders
DCC Ignore: Set to Ignore all except
[ List box ] add *.rm *.ram etc
Section: DCC - Fserve
Max FileServers Set to 3
Max DCC gets per user Set to 1
Total Max cps Set to your maximum SEND speed
Section: DCC - Server
Enable DCC Server Check
Listen on Port 59
Listen for Check Send and Chat
Check Fserv only if you run a fserve
Perform DNS Lookup Check
Section: General
Window Buffer Set to 1000 / 2000 (Increases scroll back buffer for all windows)
Router Setup.
Host Address etc. As instructed by your ISP
PC IP addresses: Do not use DHCP.
Must assign manually.
Port forwarding will not work if you assign PC
addresses with DHCP
Port Forwarding:
Forward the following ports to the machine you run
mirc on.
59-59 TCP DCC Control Port
113-113 TCP Identd
12340-12349 TCP DCC Send Ports
Bind Sockets to (or similar) Ignore it.
This works for me.
Need more help, find be in #yclept of Dalnet
Vendor Info:
www.dlink.com
www.linksys.com Port forwarding by range in firmware 1.38.5
www.netgear.com Port forwarding by range in firmware 3.25
*end*
Thanks for the help!
Had to get a new router / modem and evrything fine now. Must've been crummy router software. Not getting USR again.
> Environment:
> General:
> 1. Configure mIRC
> Security.
> www.zonealarm.com
> mIRC Setup: (ALT-O)
> Client or Server.
> Port Must be 113
> Section: DCC
> DCC Ports
> First Set to 12340
> Last Set to 12349
> Listen on Port 59
> Section: General
> Router Setup.
> addresses with DHCP
> Port Forwarding:
> mirc on.
> 113-113 TCP Identd
> This works for me.
> Vendor Info:
> www.dlink.com
> *end*
