USB connection help
USB connection help
I've just signed up and got my own hardware.... A speedtouch 530 off ebay for £40 (I digress)...
I'm having a problem getting the connection set-up. The modems installed and everything but I cant seem to get the connection set correctly..
The modem's attached via USB, but I cant seem to get the connection to work via this
Any help would be most appreciated...
Cheers
USB connection help
You can use this with USB or Ethernet have you tried ethernet. USB is always a bit funny to set up.
We need more info on your problem before we can help can you get it to connect is there any error messages
USB connection help
Ethernet is prefered since you need to additional setting up on your PC to use it.
