Two ADSL modems......one account?
Im looking into this. Can two
adsl modems plug into the phone line and run from the same connection,
with the same a/c?
If anybody knows the answer please give me a shout back, im desperate to find out. I would have thourght it was possible, but i need some pointers!
Help
Skrib......
chino
RE: Two ADSL modems......one account?
No i cannot as you can only connect once, if you are only use one modem at one time then you are fine, the best option is make a small lan and use internet connection sharing..
cUnDaLl
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
As the other post suggests, it's unlikely you'd be able to run both modems at the same time.
The solution I went for was to get a D-Link DSL-504 ADSL router which allows me to connect 4 PCs at the same time. Router cost me about £100. Obviously each connecting PC needs a network card, but most new PCs have these as standard & you can get them for under a tenner anyway. Future plan is to plug a Wireless Access Point into the router & then I can connect my notebooks anywhere in the house or garden - if we get a summer next year I'll be able to work from my sun lounger, sipping a cocktail by the pool Smiley
> with the same a/c?
> Help
> Skrib......
More than 1 PC at same time?
7 conections.. or 4.
why would anyone want to connect all that ammount of computers or Palm hand helds at same time.
Do you have an internet cafe?.
:confused:
Jason
chino
Mabe if they have there own server as i am going to be running a ftp server, however you can run a ftp server and surf the internet all on one pc however the ftp server would run slow so it's better to have one cpu for a server and one cpu for normal surfing..
cUnDaLl
No internet cafe, just a wife and 2 kids - so there's often at least 3 of us wanting to do different things online at the same time......
> :confused:
> Jason
