Tweaks For My 2MB!
Tweaks For My 2MB!
Hi guys, i have the 2mb IP STREAM service, i havent been happy with the web browsing and downloads speed...only been reachin like 180/90k max Sad what are the best possible tweaks for MTU and RWIN settings, and what program should i use to do this.I'm using Dtcp program just now! help, thanx.
madswitcher
Tweaks For My 2MB!
If you look through the MTU tweak thread, above you may find some tips. I have them set to 1478/63272 for my 2M link and get about 1.92 through a Dlink DSL 504.
In one of the threads above, i was investigating using a Draytek Vigor 2600 modem/router and the speed dropped to 1.86Mbps with this device.
Just found that you also have to set the modem/router MTU as well
Cheers, Mike
Tweaks For My 2MB!
thanx mate, i will give it a whirl! Smiley
