Tweak again
rikmoncur
Tweak again
Following advice from a user on adslguide I did he following (I've previously tweaked twice in the last few days.)My results are almost identical to the other user.
My ADSL speed test approx 2 mins ago, came out at 63Kbps downstream.
However I've downloaded a program called DRtcp, from
www.dslreports.com/front/drtcp.html
Make the following alterations, using the program:
Tcp Recieve Window =14180
Dial Up (RAS) MTU = 1458
MTU = 1458
Now I've got 451Kbps downstream!
RE: Tweak again
This is well worth doing.
I have 2 machines connected via a router.
Both were slow.
Applied tweek to machine 1.
Bingo! Fast.
Tested Machine 2 again - still slow
Tweeked machine 2
Bingo! Fast.
I think that proves it Smiley
If you're not happy registry hacking, use DRTCP from www.dslreports.com.
Call me an old sceptic if you like, but I bet it slows down again when everyone's applied this change....
Smiley
> MTU = 1458
chino
RE: Tweak again
I think i will have to try this even though my connection is fine...
however i could nto find DRTCP, could somone please point me to this..
thanks
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
rikmoncur
RE: Tweak again
