Turbocomm USB ADSL modem Linux support???
Hi all,
I signed up for the starter pack and the modem I was sent was the Turbocomm USB ADSL modem. Does anyone know if this is Linux compatible (Mandrake preferably) and where i could get drivers for it??
Cheers,
Sean.
1 REPLY
If it's the EA100, you're in luck, according to the Linux USB overview.
You can download the drivers from here.
If you have any problems with Mandrake, try www.mandrakeusers.org - they're very helpful! Smiley
