Transferred Now no broadband???
Got transfered on the 2nd with no opt out choice & by 11pm on the 3rd lost all broadband connection Sad
My dsl light is fine & dials up but doesnt get past the username password check without failing, any ideas, ive raised a question but no reply, 24 hrs without broadband now & not happy as i need it for work Evil
how does it fail any error messages? What equipment are you using?
Its worth redoing all the settings and reentering username password.
Thanks for your reply but its re-connected strangely within minutes of me posting my problem? I did try what you suggested before i posted & it made no difference, im connected at over 4mg now so im guessing it was due to the upgrade Cheesy
Trapper_Dave
I've lost all connection since the line upgrade recently. After reading on the fora, a few people have said tha Belkin routers don't support PPPoA, is any able to connect using Belkin router since the line upgrade?
