This Fix Thing (dr tcp)
How exactly do I do yhis. In the first part on the left it says tcp recieve window, what do i put there?
Then what do i put where it says dial up (ras) mtu?
Then right at the bottom right it says mtu, what do i put there?
Also where it says adapter settings all it has got is,realtek RTL8139/810XFAMILY PCI FAST ETHERNET NIC.
IS THIS RIGHT? II'M USING A FUJITSU FDX310 USB MODEM. ANY HELP WOULD BE GRATEFULLY RECIEVED.
RE: This Fix Thing (dr tcp)
Adrian
Put the same values in both of the boxes then reboot your system.
Steve
> Adrian
> Steve
I actually meant put 14180 in the recieve window
and 1458 in both the MTU boxes. Once rebooted the changes should take effect for your modem.
Steve
