Thinking of upgrading to broadband.....
Coupla questions b4 I upgrade:
I got my domain name and web space with PlusNet - do I get to keep them and are there any charges associated with keeping them?
Im gonna self-install, what hardware to PlusNet reccomend? (be nice if you gave me budget and best options).
RE: Thinking of upgrading to broadband.....
Yes you can keep these and there will be no charges for doing so, you should find the upgrade process is fairly seamless.
We don't specifically recommend particular hardware however we do provide our own hardware starter packs, these include one of:
Dynamode A220 PCI modem
Dynamode A360 USB modem
Solwise SAR110 router
You may also wish to have a look at http://www.adslguide.org.uk as they have a number of hardware reviews.
Kind Regards,
Rob
| Robert Kelly.....................Unmetered & ADSL solutions
| Technical Support...................for Home & Business
| PlusNet Technologies Ltd...........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
Thanks for the quick reply.
Ill check that site.
