Thicky in need of Max advice please
lockettpots
Advice please.
I am on my eleventh day of MaxDSL and have religiously rebooted my router every day.
PN report my stable rate as 7000
My router stats report
SNR Margin	14.3	26.0	dB
Line Atten. 13.8 8.5 dB
Errored Seconds 0 1
Loss of Signal 0 0
Loss of Frame 0 0
CRC Errors 0 1
Data Rate 7616 448 kbps
Latency INTERLEAVED INTERLEAV
These are my PN speedtest results
24-10-2006 15:05:50  	1613.5
24-10-2006 15:05:21 1432.3
24-10-2006 15:04:53 925.8
24-10-2006 15:04:34 2937.3
24-10-2006 15:04:14 632.9
24-10-2006 15:03:53 820.1
24-10-2006 14:49:40 2573
24-10-2006 14:49:22 516.2
24-10-2006 14:48:57 1072.4
24-10-2006 14:48:33 2470
24-10-2006 14:48:13 997
24-10-2006 14:47:26 3387.7
24-10-2006 14:47:00 3668.8
24-10-2006 14:46:38 967.4
I've tried the BT speedtest but after entering my phone no. it just hangs on "checking user details"
Surely I should be seeing better results from the PN speedtest.
What is my next step?
Please be gentle with me I'm a fairly inexperienced user of great age!!!
From what I've heard the PN speedtest is not very reliable...try one of these....
http://www.speedtest.bbmax.co.uk/
http://www.speedtest.net/
http://www.adslguide.org.uk/tools/speedtest.asp
lockettpots
Adslguide speedtester gives
2466.2
2348.0
2559.8
better speeds then huh! :lol:
lockettpots
But hardly what I had expected Sad
Well I suppose not, when I intialy got BBMax I was expecting speeds of around 5000 as my line syncs at around 6400 but can go as low as 4500. But my PN stable rate was upped to the max 8000 as requested but my BT IPprofile is stuck at 4000 and I get speedtest results of 3800 maximum and it's retty reliable. But until ypou can see what your IP profile is set to there isn't much PN will do without them results.
just keep trying and you WILL get a result eventually.
