The question is ! When my Broadband comes, with USB Modem ,
cswatt
I am waiting for activation for broadband, next week hopefully, (Come On BT.. Cheesy )
I have 2 computers running win2000 Pro, networked via 2 PCI Network cards, and one crossover cable. All working , browsing through ICS. All works perfect surfing on a 56K modem .
The question is ! When my Broadband comes, with USB Modem , will the ICS still work after the modem is installed on the (Server), or will I need to change the setting for ICS.
I have been thinking about getting a router/modem. Would anyone recommend a model?
We have a D-Link DSL 504 router at work and it works fine for the 6 PCs here.
Hope this helps you.
:lol:
i am using a netgear DG824M wirless for a mac and PC great results and easy to.
cswatt
Thanks for the info
Cheesy
Thanks for the info about the routers, I have been surfing, looking for advice on the *Best* :? One too buy , seems like all are best ! .
Well thats good marketing I guess .
[Moderator's note (by acarr): Removed duplicate reply]
