The Netgear DG834PN and MaxDSL
My max speed listed on my account is 2meg, yet my netgear DG834PN still lists connection speed as 512, no matter how many times I attempt to reconnect, reboot, unplug line in etc.
a few stats...
System Up Time 00:35:37
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 14752 11920 0 7976 4935 00:16:45
ADSL Link Downstream Upstream
Connection Speed 576 kbps 288 kbps
Line Attenuation 15.5 db 31.5 db
Noise Margin 26.6 db 23.0 db
Any suggestions?
1 REPLY
shellsong
It looks as though you are on one of the old fixed rate accounts rather than MaxDSL so no amount of router rebooting will do anything. Also I find your attenuation and SNR figures puzzling-- are you sure you haven't got the downstream and upstream data swapped?
