The Fix
The Fix
How do I do this fix thingy MTU and RWIN, I'll try anything with the way my speeds are going.
RE: The Fix
look at http://www.adslguide.org.uk/guide/mtu.asp
I you have a PCI modem, this will only work for the RWIN value, see my post to see how to adjust PCI modem settings: http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=plusnet&Number=462102&page=1&view=expanded&s...
RE: The Fix
Ive downloaded that dr tcp what and where do i put the values
RE: The Fix
RE: The Fix
Top left, Tcp receive window is RWIN and bottom right is MTU. select your adaptor first on the left and then enter 1458 for MTU. Save then exit and reboot, you can check if it's worked by going to
http://www.broadbandreports.com/tweaks and running the test and reading the values
RE: The Fix
What do you do if you USB modem doesn't appear in the LIST? I have a USB usr 9000
RE: The Fix
The real fix would be to hit your PC with a hammer and give up!. this will never end.
Jason
RE: The Fix
Changing the MTU to 1458 worked great for me before i changed settings i was getting 3k on downloading gamespy now i'm getting a tasty 58k!
thanks
phil.
RE: The Fix
Hey Hey - me too. 1K to 3K before, now:
Your current bandwidth reading is:
533.60kbps
which means you can download at 66.7 KB/sec. from our servers.
Whooooo!!
