Thanks for the tip
ESL
Thanks for the tip
Thanks for the tip, I'll have a scoot around and look it up.
I'll post back in time, when I have bought something and on how I fared with installs etc.
Cheers
George Smiley
ESL
Router Recommendations?
Hi all,
I am looking to buy an ADSL modem/router and don't have a clue where to start. I have a Dual Boot Windows XP/98SE PC, 10/100 ethernet card, and may want to network an Apple Imac sometime in the future. :?
I don't particularly want to to go wireless right now due to the additional expense,but would like something easy to set up on PlusNet. It should provide at least 2 ethernet sockets, built in firewall and if possible full uPNP to support MSN Messenger video and audio.
I'm quite happy to purchase new, or second hand off Ebay if a now-discontinued product is worth seeking out.
Hope someone can help with a recommendation Smiley
Regards
George
Recommend Zoom X3, have been using for a year now with no problems.
This has only one Ethernet but it is to use with a hub which would enable you to use different computers and o/s
I am now on with Win98, but have got RedHat 9 Linux on another and also a laptop.
Have no idea of current price, but was just under £100 when I bought mine.
Harry.g
Refer www.zoom.com for details
mssystems
The Zoom X3 (and quite a few others) uses the same Connexant chipset as this 4 port switch/router
http://www.novatech.co.uk/novatech/specpage.html?NOV-ADSLR4
You can see a data sheet for the same switch under a different brand name here
http://www.avgs-tech.co.uk/ORIGO/ASR-8400.pdf
The Zoom X3 does has a much better WebUI and is an absolutely solid performer. You will have to decide if it is worth the extra 50 quid.
Regards
Matt
www.mssystems.co.uk
ESL
HI Guys,
I have had a quick nose around and found info about the Zoom X4 as well as the X3. I presume this is an updated model :?:
Or are you saying the X3 may be better, cheaper :?:
ESL
Hi again,
Done a little bit of nosing around and found that the X3/4 con't support UPnP. What this means to me is that I can't use MSN Messenger/Netmeeting with audio and video Sad
As I need to do this I need a router with UPnP support. As far as I can find out, only the Thomson Speedtouch 510 has support for this.
Unless you guys no better... :?:
I use a SpeedTouch 510 and it certainly has UPnP support. But it is no longer the only router with this feature. I know recent Netgear routers (eg DG8x4), and no doubt others (eg Vigor?) do as well.
