Terrible pings
Terrible pings
Pinging portal.plus.net [212.159.8.137] with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=320ms TTL=249
Reply from 212.159.8.137: bytes=32 time=319ms TTL=249
Reply from 212.159.8.137: bytes=32 time=318ms TTL=249
Ping statistics for 212.159.8.137:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 318ms, Maximum = 320ms, Average = 319ms
Anyone else seeing such poor pings?
Terrible pings
yes whatever site I ping or onlie gaming, its all slow at the moment, ive had no reply to my contact ticket and am beginning to get a little cross
Terrible pings
Can you both post the results of a 5 min WinMTR test as text as this will show how bad your pings are ans if any packet loss is occuring.
Terrible pings
Yeah, just assume that we're all running windows. Oh well, nevermind....
Terrible pings
What operating system are you using?
Terrible pings
In which case, use MTR.
WinMTR is simply a windows spin-off of the original *nix application.
Terrible pings
downloading app now,
thank you for a reponse
edit, sorry but any chance of explaining how to use this in full so that the data I give is useful to you?
Terrible pings
here is the best I can master:
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| No response from host - 100 | 5 | 0 | 0 | 0 | 0 | 0 |
| lo1.plusnet.pth-ag2.plus.net - 0 | 5 | 5 | 0 | 15 | 31 | 15 |
| gi1-2.vlan3.pth-gw4.plus.net - 0 | 5 | 5 | 93 | 109 | 140 | 140 |
| ge1-1-0-23.ptn-gw1.plus.net - 0 | 5 | 5 | 94 | 109 | 125 | 125 |
| rt-linx-b.thdo.bbc.co.uk - 0 | 5 | 5 | 109 | 124 | 156 | 140 |
| 212.58.238.129 - 0 | 5 | 5 | 109 | 112 | 125 | 125 |
| 212.58.238.34 - 0 | 5 | 4 | 109 | 117 | 125 | 109 |
| 212.58.239.30 - 0 | 4 | 4 | 109 | 121 | 125 | 125 |
| 212.58.228.154 - 0 | 4 | 4 | 109 | 121 | 125 | 125 |
|________________________________________________|______|______|______|______|______|______|
WinMTR - 0.8. Copyleft @2000-2002 Vasile Laurentiu Stanimir ( stanimir@cr.nivis.com )
Different site
| WinMTR statistics |
| No response from host - 100 | 4 | 0 | 0 | 0 | 0 | 0 |
| lo1.plusnet.pth-ag2.plus.net - 0 | 4 | 4 | 15 | 15 | 16 | 15 |
| gi1-2.vlan3.pth-gw4.plus.net - 0 | 4 | 3 | 109 | 109 | 110 | 109 |
|ge-4-1.metro1-londencyh00.London1.Level3.net - 0 | 4 | 3 | 109 | 114 | 125 | 125 |
| so-1-3-0.gar2.London1.Level3.net - 0 | 3 | 3 | 109 | 140 | 187 | 187 |
| ge-11-0.ipcolo1.London1.Level3.net - 0 | 3 | 3 | 110 | 110 | 110 | 110 |
| No response from host - 100 | 3 | 0 | 0 | 0 | 0 | 125 |
It would seem the pings are bad
Terrible pings
The ping issue on gw4 is known and it also appears to be happening on gw3. Plusnet are investigating but can't find a fault yet.
Also those tests should be run for at least 5 mins (300 pings) to give proper results.
lowry
Terrible pings
firedragon,
gw3 & gw4 issue is discussed in this thread if that's of any help.
matt Wink
Terrible pings
Is this issue still going on?
Im getting pretty poor resutls from my connection now. (which is odd since it was fine earlier)..
This is what I got from Winmtr
| WinMTR statistics |
| lo1.plusnet.pth-ag2.plus.net - 0 | 109 | 109 | 0 | 15 | 32 | 16 |
| gi1-2.vlan3.pth-gw4.plus.net - 0 | 109 | 108 | 235 | 294 | 547 | 281 |
| gi4-0-23.pth-gw2.plus.net - 0 | 109 | 108 | 234 | 295 | 469 | 297 |
| atm0-1-0.ptb-gw1.plus.net - 0 | 108 | 108 | 234 | 308 | 531 | 328 |
| vl4.sec.ptb-gw3.plus.net - 0 | 108 | 108 | 250 | 300 | 360 | 313 |
| if2.ptb-al1.plus.net - 0 | 108 | 108 | 234 | 299 | 359 | 313 |
| portal.plus.net - 0 | 108 | 108 | 234 | 298 | 359 | 313 |
Terrible pings
i'm getting the same problem....was fine this afternoon....now im getting pings of 300/400 on any server i go on....everythings acting as if i was still on my 56k Evil
| WinMTR statistics |
| lo1.homesurf.pth-ag1.plus.net - 0 | 178 | 178 | 0 | 38 | 280 | 60 |
| gi1-2.vlan16.pth-gw3.plus.net - 1 | 178 | 177 | 220 | 312 | 710 | 280 |
| gi4-0-23.pth-gw2.plus.net - 0 | 177 | 177 | 220 | 310 | 610 | 270 |
| atm0-1-0.ptb-gw1.plus.net - 0 | 177 | 177 | 220 | 323 | 820 | 280 |
| vlan18.pri.ptb-gw4.plus.net - 0 | 177 | 177 | 220 | 326 | 720 | 330 |
| if2.ptb-al1.plus.net - 0 | 177 | 177 | 220 | 325 | 660 | 280 |
| portal.plus.net - 0 | 177 | 177 | 220 | 325 | 550 | 270 |
Terrible pings
| WinMTR statistics |
| 192.168.7.1 - 0 | 251 | 251 | 0 | 0 | 16 | 0 |
| lo1.plusnet.pth-ag2.plus.net - 0 | 251 | 251 | 0 | 17 | 219 | 16 |
| gi1-2.vlan3.pth-gw4.plus.net - 0 | 251 | 251 | 250 | 301 | 641 | 344 |
| gi4-0-23.pth-gw2.plus.net - 0 | 251 | 250 | 235 | 300 | 547 | 344 |
| atm0-1-0.ptb-gw1.plus.net - 0 | 251 | 250 | 250 | 313 | 688 | 344 |
| vl4.pri.ptb-gw3.plus.net - 0 | 251 | 250 | 235 | 307 | 422 | 360 |
| if2.ptb-al1.plus.net - 0 | 250 | 250 | 250 | 307 | 516 | 360 |
| portal.plus.net - 0 | 250 | 250 | 235 | 307 | 547 | 360 |
Having the same sort of issues here as well.... All I wanted to do was play Counter-Strike: Source Sad
southerncomfort
Terrible pings
These are my results. Pretty pissed off...
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Mike>ping bbc.co.uk
Pinging bbc.co.uk [212.58.228.154] with 32 bytes of data:
Reply from 212.58.228.154: bytes=32 time=156ms TTL=248
Reply from 212.58.228.154: bytes=32 time=181ms TTL=248
Reply from 212.58.228.154: bytes=32 time=165ms TTL=248
Ping statistics for 212.58.228.154:
Minimum = 156ms, Maximum = 181ms, Average = 164ms
Think I'll be off soon.
Terrible pings
Managed to hook a PC up to my connection, and sure enough the pings are still definitely a joke:
| WinMTR statistics |
| No response from host - 100 | 301 | 0 | 0 | 0 | 0 | 0 |
| lo0.plusnet.pth-ag1.plus.net - 5 | 301 | 287 | 15 | 740 | 1110 | 578 |
| gi1-2.vlan3.pth-gw3.plus.net - 17 | 300 | 250 | 31 | 771 | 1110 | 532 |
| gi4-0-23.pth-gw2.plus.net - 16 | 300 | 252 | 31 | 768 | 1250 | 453 |
| atm0-1-0.ptb-gw1.plus.net - 15 | 300 | 256 | 62 | 803 | 1203 | 687 |
| vlan18.pri.ptb-gw4.plus.net - 15 | 300 | 257 | 47 | 786 | 1172 | 781 |
| if2.ptb-al1.plus.net - 17 | 300 | 249 | 16 | 788 | 1110 | 671 |
| portal.plus.net - 18 | 300 | 247 | 32 | 794 | 1141 | 578 |
When will this be sorted out?
