Terrible download speeds
I'm getting terrible download speeds - currently from download.com I'm getting between 10 and 15Kb/sec. Was the same this morning and yesterday so I don't think it's a specific site issue. Is there any particular reason?
Thanks,
Matt
Maybe you are over your download limit? If your on Broadband Plus you can only download 4gb at peek times each month. Check this by going to connection settings and clicking on usage. hope this helps
Plusnet Staff
Plusnet Staff
Is it just download.com you're having problems with or do you notice slow speed from other sites as well? I just downloaded a small file from there at about 240KB/s.
