Telephone splitters
Telephone splitters
Hey guys, bought a new cordless telephone today (old one was looking a bit outdated you know) and i get 'noise' on the line from my ADSL connection and internet fails to work when its in use. The ADSL from the router go's through an extension cable via a microfilter then a splitter in the socket.
Funny thing is it worked fine with the old phone, so my question is first of all why is this the case and secondly do i just need a better quality splitter and if so where?
Thanks in advance guys, got me puzzled!
Fixes: 69
Telephone splitters
Not sure if I understand you correctly but it sounds like you may have 'double-filtered' the line. Check out the wiring guides here: http://usertools.plus.net/tutorials/id/13
You can purchased BT approved filters like the one here.
Kind Regards,
Plusnet Products Team
Telephone splitters
DECT digital cordless phones are known to cause problems with some makes of microfilter. I assume the base unit is connection to your wallsocket via a microfilter. If not, this is your problem.
2 microfilters that do work with DECT phones are the Excelsus Z-420UK-A Dynamic ADSL Microfilter or the XF-1e Professional ADSL Microfilter
Telephone splitters
Can you describe your setup in more detail. I need to know where your phone is connected, and where the filters are in relation to the extension.
Your setup sounds something like mine, where I have the router upstairs on an extension, but my phones and sky downstairs. I have two filters and 2 spliters. The spliter on the master socket, connects one to the extension and one to a filter. The phone and sky connect via a spliter to the filter.
The extension is not filtered at the master socket, but rather at the end where the router connects.
