Telephone Woe
xon
Telephone Woe
Hi All
Please follow this link to understand my issue.
http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=technical&Number=761834&page=0&view=expanded...
Has anyone out there got a solution?
Keep smiling Tongue
Andywit
Telephone Woe
Yes what a tail of woe Shockedops:
All I can suggest is similar to the Adsl forum in that you just try one filter on the master socket with one phone and your pc to it .
If this doesn't work borrow a know working filter and try that .
If it still doesn't work nip next door and borrow their phone and try that.
If it still doesn't work then I think its a call to BT.
Telephone Woe
Unscrew the face plate on the master socket and use the 'test' socket inside, using a single micro filter, this way you can be doubly sure that any hardwired extensions are discounted.
Chris
