Telephone / Broadband interference
Not sure if this has been covered before so I apologise if it has.
Does anyone have problems with the internet connnection freezing whenever the telephone is used at the same time ?
If my wife uses the phone line everything on the internet connection freezes and I am unable to get connection, download, webpages etc. As soon as the phone call is disconected all is OK again :?:
Probably a problem with your filters or wiring. Check this guide in the tutorials forum for help.
Chris
Thanks for that. Just checked the filters I have and I forgot thr Sky box. Will get another and try again
Try unplugging the sky box first and see if the problem goes away, it might not be the cause of your problem (although it sounds likely) and you might have faulty splitters on one of your phone.
Chris
