Teamspeak Problems
Teamspeak Problems
Im having difficulty using certain teamspeak servers. Most of them work fine, but the one I use on a regular basis is causing a problem. Most of the time I get a time out before it will connect, and when I do connect my ping goes insanely high. I remember a thread about TS issues a few months ago, but the problem went away. Well now its back, any suggestions?
Fixes: 9
Teamspeak Problems
If it's only with one particular server then it sounds like one of 2 things:
1) The TS server is overloaded or on a bad connection
2) PN have filtered the TS servers address and are intentionally throttling that connection for you.
Personally I don't trust PN one little bit but it would be a bit unlikely for them to single you out for just one TS server.
Have you contacted the server admin?
bikepump
Teamspeak Problems
i had exactly the same thing ... tried everything and 2 weeks after it started .... it just vanished and i've had no ts problems ever since :?
