Takes 30+ mins to connect ??????
Any idea why my it would take at least 30 minutes for my adsl to connect?
Once connected its fine and can be up for days at a time.
Its very annoying when you just want to "quickly" check your emails and you have to wait half an hour or more untill it connects.
Hope someone can help me
RE: Takes 30+ mins to connect ??????
Try changing modulation to ANTSI (think those are the letters). I had the same problem..
I have found that my connection keeps dropping now and not reconnecting what I do to get it to reconnect is to change to gdmite lite of whatever and back to ansi and then it reconnects. Hope this helps.
coley
Hey thanks Colin worked perfectly!!!!!!
u r the man!!
:bandit:
Please tell me your NOT using the modem supplied in the "ADSL PCI Starter Pack", that is you're problem right there in front of you...read my other posts or go here for my review:
http://www.consumer-reviews.co.uk/topic.asp?ReviewID=7174&SubCatID=104276&CategoryID=254&SubMainID=2...
:bandit:
Just like to add this solved my problem perfect Smiley
