Take a look at my results from speed test
can anyone interperate the below result, you can see the speeds i was getting now all of a sudden it has jumped right up and i am on a 1mb connection.
PlusNet Speed Test
Your current speed is:
1.80 Mbps
Which means you can download at 230.44 KB/sec. from our servers.
53.3 kbps 56k Dial Up
64 kbps ISDN 1 Channel
128 kbps ISDN Dual Channel
460 kbps ADSL 500
920 kbps ADSL 1000
1840 kbps ADSL 2000
1843.5 kbps YOU
The following table shows the speeds you achieved from previous runs of the speed tester:
Date Speed Achieved (kbps)
11-01-2006 23:25:38 1846.7
24-11-2005 13:48:31 927.4
22-11-2005 18:25:14 962.3
No I'm sorry but you will need a rocket scientist to work out what has happened!
Tongue
You have been regraded to 2Mb simple as that. Congrats. Smiley
Thanks for that but i had no idea that i was to be upgraded lol, nobody told me.
What is the use of me being upgraded if my downloading doesent appear to have gotten any faster lol.
When it says i can "download at blah blah blah from our servers" what are these servers then and what is on them to download.
Reboot your router/system, maybe leave it switched off for 20 mins or so. See if that sorts it! Smiley
*EDIT*
It means from PN speed test server, however if you are not seeing this elsewhere then do as I said above and try a speed test from another site.
