TCP settings
TCP settings
A friend has recently joined plusnet and has a USB modem. Is it still necessary to change the TCP and RWIN values? She seems to be getting intermittent connections.
Dave
RE: TCP settings
> Thanks
> Dave
Yes she does need to change the RWIN and MTU, i've had the same problem at peak times, i think it's down to BT they can't handle.
RE: TCP settings
Hi David
FYI the MTU should be 1458. Its a feature of some cisco kit used by bt.
Kind regards
Lyndon
