System tray icon gone
With my other ISP connection I had this connection status icon in the system tray but after moving to plusnet and running autoconfiguration files the icon is gone. How can I bring it back up?
Look in Network and Dial-up Connections if you have the icon on your desktop or in windows control panel. In there look for the Modem or Lan connection icon, double click it and look in its properties for the Show Icon in taskbar when when connected box and tick it.
But if you are using a USB or PCI modem it might also be in the modems own control panel.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Thanks, it worked
