Synch Rate gone mad - Help!
Hi All
Can anyone have a look at my modem stats and let me know if they are ok, my BRAS & typical synch rate has went from 7500kbps before interleaving was applied, down to 7000kbps with interleaving aplpied, then down further to 5500kbps after interleaving has been turned off again, can you please look at my line stats and tell me if you see anything odd and why I am synching so low (6600kbps is low considering I used to connect at 8103kbps in the past with fast channel, so what's changed in 6 weeks??
You can see my CURRENT router stats here with interleaving OFF:
Here
And my OLD router stats with interleaving turned ON:
Here
A.
shellsong
Your SNR seems high enough for you to synch up at 8128 Kbps as long as it is reasonably stable and your target SNR was the default 6 dB. I guess if you reconnect your router every day or so it should come back up in a few days unless there are other issues-- if not ask PlusNet whether someone's been messing with your target SNR
You have both interleaved and Fast path errors, so it seems as though somebody has left you partly interleaved and partly fast path.
The stats show interleaved FEC errors, the rest show fast path.
