Sync problem
Craigiusmaximus
Sync problem
Hey people i have just moved to plus net for my BB and i am unable to sync in with the exchange i have had plus net test the line and they have given me these results im using a Linksys wireless router and i used it with the previous ISP yet i can sync with plus net in the exchange could someone suggest any ideas?
I have tried to swap microfilters no joy
i have a hardwired extension going into the back of master socket which goes into an upstairs bedroom could that be the problemHuh When BT came to test the line they said an extension in the house was affecting the BB signal could someone help
By the way the plus net support is very good im happy with that side of things.
The following comment was added to the ticket
xDSL Status Check Analysis
OK.
Circuit Information
Circuit In Sync
Upstream xDSL Link Info
Loop Loss 31.5 dB
Cell Count 1201885361
Downstream xDSL Link Info
Loop Loss 57.5 dB
Cell Count 827838086
Determine Algorithm Branch Analysis
Continue to copper line test.
Copper Line Test Analysis
Test OK.
Diagnosis T005 : Line Test OK
MFL OK
Duration 31
OK.
Circuit Information
Circuit In Sync
NTE In Service
NTE Power On
Bypass Not Activated
MUX In Service
Loop Loss 31.5 dB
Margin 26 dB
Errored Seconds 6
HEC Errors 8
Cell Count 1201970851
Speed 288 k
Loop Loss 57.5 dB
Margin 12 dB
Errored Seconds 14
HEC Errors 0
Cell Count 827850110
Speed 1152 k
LiamM
Sync problem
Welcome to the boards.... Smiley
I'm guessing you've tried direct into the master socket with nothing else connected, and even no microfilter? And this still doesn't work?
And you've tried with other equipment? A different router / modem?
If both of these tests fail, it sounds to me like this is a BT issue.
Plusnet, unfortunately, have nothing to do with the sync to the exchange - if you cannot sync, that can only be an internal problem or a BT issue.
Any troubles with the voice line at all recently? Your line stats look fine for 1Mb.
Craigiusmaximus
Sync problem
Hi mate thanks for the quick reply what do you mean by connecting with no micro filter??
as for other equipment yes i have tried...
hitachi
Sync problem
Surely for plusnet to have been able to conduct the woosh test the router has to be in sync.
