Sync but no page browsing
Hi there.
I now finally have a sync (after more than a month since my activation!) but am not able to browse any web page. Does anybody have any suggestion of what the problem could be?
(I can connect both with my username/password and with bt_test@startup_domain but, in either cases, cannot see www.bt.net/digtaldemo. My modem/router is an SMC7401BRA on Mac OSX.)
[by the way, CS closed my latest ticket (without it being inactive), notwithstanding the fact that I had asked them to close it myself. I think they do that for statistical purposes]
Thank you
Dante Leone
RE: Sync but no page browsing
> Hi there.
> Thank you
Are you using it to connect a network as a router, or using it as a modem with the USB cable?
I have the same router/modem plugged into the uplink port on my network switch. Check you have the correct gateway address, and your other tcp/ip settings. I'm a windows user, so can't advise how to do it with a Mac.
> Dante Leone
So far, I use it as a modem but via ethernet rather than USB. I think the computer settings are fine (otherwise it wouldn't connect to the router). Maybe it's got something to do with the router settings?
dante
