Sync Speed Issues - Ticket 20548064
sophos9
My router is syncing at 480kbps after an initial 2mb connection when moving house
Line stats are as follows...
Local Tx Power: 12.13 dB
Remote Tx Power: 13.73 dB
Local Line Atten.: 53.0 dB
Remote Line Atten.: 30.5 dB
Local SNR Margin: 14.5 dB
Remote SNR Margin: 16.0 dB
Strange thing is, upload is the same as it was on my old 8mb connection, plusnet have my rate set at 8000kbps and BT say I should get a 3.5mb dslMAX connection
I have connected for over 24hrs in the NTE5 test port, conducted a quiet line test and ran 3 BT speedtest now despite being asked to perform a woosh test, plusnet just say they will get BT out...
Can someone please help me....
sophos9
Excellent, PN have ran a test:
Analysis
OK.
Circuit Information
Circuit In Sync
NTE In Service
NTE Power On
Bypass Not Activated
MUX In Service
Upstream xDSL Link Info
Loop Loss 30.5 dB
Margin 22 dB
Errored Seconds 0
HEC Errors 0
Cell Count 275504
Speed 448 k
Downstream xDSL Link Info
Loop Loss 52 dB
Margin 16 dB
Errored Seconds 0
HEC Errors 0
Cell Count 1182621
Speed 512 k
DSL MAX
Downstream Line Rate 288
Downstream Line Rate Timestamp 20/10/2006 18:04:20
Maximum Stable Rate Re-set (Y/N) N
Profile Change Time 20/10/2006 17:44:36
Maximum Stable Rate
Fault Threshold Rate
Interleaved Auto
When does the Downstream rate timestamp adjust?
How can you get the MSR reset and how come the Fault Threshold Rate does not appear?
Many thanks...
sophos9
Good news, summin has changed!!!
Rebooted the modem and got the following stats:
Config Data Up Down
Intrlvd Fast Intrlvd Fast
AS0(kbps): - - 1728 0
AS1(kbps): - - 0 0
LS0(kbps): 448 0 - -
LS1(kbps): 0 0 - -
RValue: 4 0 16 0
SValue: 4 4
DValue: 8 8
Yep, thats 1728 downstream with a local SNR margin of 16.5db
That means, with a SNR of 6db, I *should* get a 3mb connection...
Yee haw! Hope it stays stable!!
shellsong
I make it more like 5 Mbps if you're lucky Wink
sophos9
Hi shellsong, fingers crossed!
Will leave router and only reboot once per day and see if the downstream sync rises as the BRAS realise the connection is stable.
Will post up with results and fingers crossed, will get some feedback from plusnet on what the issue was.
Plusnet answered my ticket exactly when they said they would last night which is promising...
sophos9
Rebooted router today, still sync'd at 1824kbps with 16db SNR Margin
BRAS have also updated which is good
IP profile for your line is - 1500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 1824 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 1364 kbps
Last Result:
Download Speed: 1410 kbps (176.3 KB/sec transfer rate)
Upload Speed: 360 kbps (45 KB/sec transfer rate)
Just wondering now, whats stopping dslMAX increasing the sync rate?Huh
sophos9
Even better news this morning!
Sync is 2432kbps with SNR Margin of 16.5db?!?
BRAS have not updated yet as IP Profile is still set at 1500kbps... No problems, I'm sure by the end of the day Wink
Strange this is, sync is slowly creeping up but SNR Margin is not going down? I think that 5mb may well be on the cards!!
ady
haha my synch is slowly creeping up aswell
i *finally* hit the 2.0mb this morning lol ! Cheesy
my SNR is 10 tho Tongue
alot better than when i use to have 0.5>0.9mb and SNR of 20 >_<
sophos9
Has your SNR been dropping when your sync rate increases?
sophos9
Just had a reply from Plusnet support, they have advised that BT have changed the RAS Mapping in my local exchange...
Now I'm out of my depth there, can any advise on what is involved when changing a RAS mapping?
sophos9
The RAS mapping refers to your circuit profile on the RAS (remote authentication server) in the exchange, it is this that governs the noise margins and speed of your connection. SNR can vary, I believe that 6db is the default however BT can and do adjust this in order to speed up or stabilise connections
Well I gotta give it to Plusnet, there support has been bang on time and they have gone above and beyond in helping! Cheesy
Should take around 3 days for my connection to stabilise now, if not, drop another ticket!
Excellent!
sophos9
Downstream sync has stabilised at 2528kbps with a SNR margin of 16db, the BRAS profile is still set at 1500kpbs though, will have to see what happens over the next few days...
sophos9
Latest update!
Sync speed has been at 2528kbps all weekend with an SNR Margin of 16db
The BRAS IP Profile is still at 1500kbps and the sync has not been adjusted up, have asked plusnet to return the fault to BT
Seems something ain't right in the exchange...
sophos9
Got the inevitable "I have further tested the line and found no fault evident on the line as your Downstream line rate is set at 2.2meg and on the speeds you are reporting indicates no fault on the line"
err... OK!
Can anyone please give some clarity around the SNR margin. As I see it, the BRAS should target as close to 6db as possible before detecting stabilisation issues.... In my case, its 16.5db and has not EVER adjusted, this is confirmed by the results of the whoosh test...
Someone... please?!?
