Switching Phone Rental Provider - Does it affect Broadband
I'm switching my line rental from BT to someone else and wondered if it will affect my broadband connection with plusnet and whether or not there are outstanding monies to BT for the modem equipment.
1 REPLY
rz2k7
No there wont be any problems with your connection as the other company you're going with will just be taking over the billing from BT for your phone calls.
As for the modem if you was with BT and they supplied the modem and then you moved to Plusnet, any outstanding monies owed to BT (ie for the modem) would have been settled when you migrated to Plusnet.
Hope this helps.
