Switch off Computer?
rumtop
Is it better to leave my computer on 24/7 to maintain max DSL speeds. Or can I turn it on and off when required? If I keep turning it off how long does it take to return to max DSL Speed?
Phil
It depends...
What ADSL modem/router do you use?
If its a separate router just leave it on and switch your PC off.
Switching your PC off/on should not have any affect on your ADSL speed.
rumtop
Thanks, Smiley
Its a separate router,so I can leave the D Link ADSL Modem on.
Phil
holdtight
Yep you can if you want to it usually comes down to personal preference and whether you want to switch it off, i leave mine on 24/7 and have no probs at all with it i just turn off the pc from time to time but thats usually left on also
rumtop
Smiley
Thanks again.
I will switch off pc when not in use, and leave the modem on.
Phil
craigbrass
I was told it isn't a good idea to switch routers off at night and I have had this proved twice.
I was told that there is a small amount of memory in a router and over time switching it on and off (as routers don't have a shutdown option) can cause problems with this memory chip.
When I say proved twice, two people I know who have done this have had their routers die after less than 3 months.
rumtop
Thanks Craig.
I will only be switching off my PC.
I will leave the router and the separate ADSL Modem on.
Phil
Smiley
router and ADSL modemHuh?
You can't have both connected to the phone line at the same time.
Unless you mean your router does not have integrated ADSL modem so the ADSL modem is separate and plugs into the router?
shellsong
Really, Peter, I guess people assume to readily that when someone says "router" on the forums they imply that there is an ADSL modem integrated with it whereas it would probably be best to say "ADSL router" or "router/modem" or similar to save confusion Wink
rumtop
To clear up any misunderstanding :idea:
I have one D link DSL 300G+ ADSL Modem and
one Linksys BEFW11S4 Wireless access point router.
Thanks again
Phil
@flashasp wrote
What happened to those routers, how did they fail?
I ask because I bought a Netgear in late May, in early September I started to get a lot of evening disconnections, and recewntly a lot of CRC errors as well, although the router is still working and holding the line to a 0 dB SNR margin and below.
I'm on a long line so a lot of routers won't work well for me, those that do tend to be expensive so I can't afford to buy another just to test. But if it is faulty I could return it to PC World under warranty.
pacem
@HoldTight
It shouldn't come down to personal preference. Leaving a modern computer on 24/7 costs around £200 per year* and has unnecessary environmental impact.
If you don't need it on, SWITCH IT OFF.
Paul.<><
*Based on fact that a 200W device costs £200 per year if running 24/7, and that the average PC idles using 200W.
(Router on 24/7 only costs about £5 per year.)
I'm with you Paul.
Energy conservation is a serious concern, and is going to be a very pressing issue sooner than most would think!
Yep I turn everything off at the end of the day. If Im not going to be using it then why have it turned on :?
As well as being good for the environment I'm also reducing the fire risk in property.
I also do the same with the TV which like all these days has a standby setting from the remote. However even on standby its still consuming a fair but of energy and I did have one actually catch fire a few years ago.
Luckily it went up in flames in the morning while I was still in the house so I was able to unplug it and dowse it. :!:
A sobering one that John! :shock:
