Success with DSL-604+?
I've configured my new router (DLINK DSL-604+) with the necessary data and I appear to connect successfuly to plusnet via ADSL. However, I can't then browse the web - I cannot access any sites. I have not altered any other settings form their factory defaults.
Any help appreciated.
stonechat
Browsing
Under Internet Options. select 'Never Dial a Connection'
Bob
One of two things may be required.
1: If using DHCP to assign a IP to your computer, then reset the DHCP data.
For XP, use the "repair" option for your network card
For 9x, release and renew from the "winipcfg" program.
2: You need to make sure your computer has the default gateway and DNS servers set.
Either start using DHCP if your router supports it, or edit your network card settings.
Thanks but already sent. However, everything is now working fine ... hopefully this will still be the case tomorrow as I don't I changed anything significantly.
