Stuck with 512kbps
Stuck with 512kbps
Hi All,
I am a very frustrated PlusNet customer. I have a Broadband Premier
account and should be entitled to 2Mbps speed, moving soon to 8Mbps.
But because of a limitation on my BT line, I can't get more than 512kbps!
I called BT, and they said they can't do anything for me and that I should
be talking to PlusNet who should try and sort this out with BT Wholesale.
However I raised this with PlusNet before and they didn't suggest anything.
So is anybody else out there in a similar situation? And is there any hope
for a solution in a not so distant future?
Cheers,
Yazid.
Stuck with 512kbps
Could you just move your house a couple of miles closer the exchange Cheesy
Chilly
Stuck with 512kbps
Ok
A more serious answer, do you know the reason why you are unable to any better rate that 512k
Chilly
Stuck with 512kbps
Well, I presume it's the distance to the exchange. But I'm not 100% sure.
Stuck with 512kbps
What ADSL equipment do you use (make/model)?
Does it show line stats? If so, post them here.
Stuck with 512kbps
Im in a similar position.. 512mb yet line stats well within 1mb. And thats before ADSL MAX
My Stats...
Down
Atten 51Mb
SNR 22Db
Hours on the phone with BT who say its down to Plusnet, Plusnet say its down to BT - total impasse
Visit ADSL guide - http://bbs.adslguide.org.uk/showthreaded.php?Cat=&Board=general&Number=2084086&page=0&view=expanded&...
Andrew at ADSL may be able to help if your line stats suggest you should get more than 512mb - appararently he has helped others and is currently looking into mine
Stuck with 512kbps
What does the BT ADSL checker say your max (non-ADSLMAx) speed. If this states 512Kbs then that is why BT did not upgrade you.
The problem is BTs BUT it has to be reported via your ISP. You can't talk to BT direct as they don't deal with ADSL, only voice line problems, it is BT Wholesale that deal with ADSL and only ISPs can talk to them - hence the possible confusion.
I suspect you will have to wait for MaxDSL or be switch to LLU to see what actual speed you will get.
Stuck with 512kbps
BT Checker has now been changed for me to 1mb prior to MAX thanks to Andrew @ Adslguide - have raised ticket with PN - but I wont hold my breath as I need the oxygen on a fairly regular basis.
