Streaming usage
Gel
Fixes: 10
Streaming usage
:?: If you have radio station {via streaming.} on for few hours in background any idea how much usage this is using against by monthly limit?
Streaming usage
What speed in bps (bits per second) does it stream at? From that you can work out what data will be transfered in a set time (minute/hour/day etc).
As an example here is a 128Kbs stream calculation:
128Kbs / 8 (bits in a byte) = 16KBytes/second *60 = 960KB/minute (~1Meg) * 60 = 57,600KB/hour (57.6Megs) * 24 = 1,382,400KB/day (~1.38GB)
So a 128Kbs stream running for a full day will download approx 1Meg per minute, 57Megs per hour and 1.4GBytes of data per day.
Streaming usage
It depends on the stream itself.
I listen to 96kbps streams, which use around 43.2MB on the PlusNet VMBU page (PlusNet sue a 1000MB in a GB figure).
What bit rate is your stream feeding at?
128kbps streams use 57.6Mb per hour
160kbps streams use 72Mb per hour.
Gel
Fixes: 10
what speed
