Strange Problem.
Strange Problem.
Well this evening I was playing Xbox live and it suddenly cut out and said something about network problems etc like it does..I tried to re-connect and it won't.
On network trouble shooting it can pass every step except the last one which is "Xbox live responding".
After I couldn't get on I went to my computer to go on MSN but realised it had d/c so I tried to log back in and got an error "8007efd".
I also can't access some sites for example:
http://www.bungie.net
http://www.xbox.co.uk
Or MSN service status.
Everything that is not working is to do with Microsoft so I'm wondering if their servers have gone down for some reason? Thanks.
Strange Problem.
I'm having similar problems..those two sites wont work, nor does netgear or the adaware website (www.netgear.com ... .co.uk works fine - http://www.lavasoftusa.com/software/adaware/)
Suggests some kind of DNS/Routing problem poss?
Strange Problem.
I just had a look at the Announcements board and it seems that the main USA network "something-or-other" has gone down.
Guess it's our fault for being up this late eh? :lol:
Strange Problem.
could you give me the url for that board?
xbl just died round at a friends house (BT b/band)
simon
ARG4241
Strange Problem.
my connection keep dropping esp when in xbox live. bloody annoying to say the least. i think i may have a problem with the wiring to my house as i think it mainly happens when it has rained. just a theory at hte moment thou. i may get a new router just in case, but it seems an expensive way just to make sure its not my router. Oh well time will tell. Any other suggestions welcome. Sad
