Still poor pings during gaming
I was hoping that todays new pipe would fix the recent "issues" with gaming, this doesn't appear to be the case, having just been playing on Barrysworld 213.221.176.39:27015 with a load of friends (mostly on plusnet) not a single one of us had a ping below 200 and were all suffering from packet loss and lag.
The problem was not with the server as other people on BT ADSL were not affected. Are there any plans to fix this soon? That said the service as a whole has been better today since the new pipe went active, web surfing is back to how it should be.
RE: Still poor pings during gaming
my pings have also drastically gotten worse.
Heres a typical ping and tracert....
C:\Documents and Settings\(V)unk>ping www.plus.net
Pinging portal.plus.net [212.159.8.137] with 32 bytes of data:
Reply from 212.159.8.137: bytes=32 time=302ms TTL=248
Reply from 212.159.8.137: bytes=32 time=288ms TTL=248
Reply from 212.159.8.137: bytes=32 time=294ms TTL=248
Ping statistics for 212.159.8.137:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 288ms, Maximum = 302ms, Average = 296ms
C:\Documents and Settings\(V)unk>tracert www.plus.net
Tracing route to portal.plus.net [212.159.8.137]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms server.mshome.net [192.168.0.1]
2 28 ms 28 ms 29 ms 105.core.plus.net [212.159.1.105]
3 311 ms 319 ms 326 ms 109.core.plus.net [212.159.1.109]
4 313 ms 336 ms 329 ms dolpiaza.core.telehouse.plus.net [212.159.1.114]
5 312 ms 326 ms 325 ms atm.core.plus.net [212.159.1.65]
6 344 ms 336 ms 335 ms 250.core01.access.plus.net.uk [212.159.15.250]
7 341 ms 333 ms 323 ms 230.core01.access.plus.net.uk [212.159.15.230]
8 304 ms 308 ms 325 ms portal.plus.net [212.159.8.137]
Trace complete.
Yup, mine are much the same if not worse:
Reply from 212.159.8.137: bytes=32 time=520ms TTL=248
Reply from 212.159.8.137: bytes=32 time=345ms TTL=248
Reply from 212.159.8.137: bytes=32 time=507ms TTL=248
Reply from 212.159.8.137: bytes=32 time=656ms TTL=248
Minimum = 345ms, Maximum = 656ms, Average = 507ms
Well, that's a whole lot better than dial up isn't it!!
yup same here on mohaa 50ms ping turned to 250ms=death rung tech support who are looking into it,think there turning the screw the wrong way cause its got worse.they said it might take a couple of hours oh well go and get my ar*e full of lead again.stevie
Same here aswell.
Just done speed test at ADSL.org which was
115kbps down & 132kbps up HuhHuh
Also just played mohaa which went from average pings of 35 before new pipe to 250/300 after.
Phantom_Flan_Fl
Add me to the list.
160 up, 131 down at ADSLguide.
Pings ranging from 289 to 379ms.
MOHAA unplayable.
Some response from Support would be nice.
Even if they just acknowledge us.
My ping to Got Hunted doubled to over 300 last night since the new pipe. And a friend on pipex was getting less than 150 ping.
Phantom_Flan_Fl
Back to 23ms now.
Is it just a peak time problemHuh
