Stick with ADSL Home or regrade to Broadband Premier?
I've been on PlusNet's "ADSL Home Self-Install" 512k package for the last 2½ years. Is there any advantage in keeping this obsolete package, or should I "upgrade" to Broadband Premier, which appears to be the modern equivalent?
There doesn't appear to be a fee applicable to changing package so it won't affect me that way.
1 REPLY
If you upgrade you will find its cheaper by a few pounds. I have been on it the same time as you and I upgraded got the 2 meg and saved a few quid
