Static IP address changes with upgrade?
With introduction of the FUP I'm thinking of a switch from the old Home Surf product to Broadband Premier to get higher speed. I have an existing static IP address - will the address change if I change product?
LiamM
Don't quote me on it, but I think your IP address does change with a move from Home Surf to Premier as I believe they use different pools of addresses. I'm sure somebody who knows for sure will pick this up and confirm either way sometime soon.
Yes, as Liam says, moving from Home Surf to Premier accounts would cause a change of IP.
