Starter Pack came home!!!
Billydakid
My starter pack arrived today (via a Green Goddess with Police Escort), and its all up and running smoothly. Even though for a moment I thought the router was faulty, but a quick call to Plusnet put that straight.
Apparently there's a setting not configured properly on the router. So if there's anybody out there who discovers that after configuring the router as instructed there's no pages being loaded in your browser, then change the "Default Route:" setting from "disabled" to "enabled" in the Quick Configuration section and it should be OK.
Keep up the good work Plusnet.
Ps. special thx to all of you who were out contributing to the search. Cheesy
RE: Starter Pack came home!!!
>> then change the "Default Route:" setting from "disabled" to "enabled".<<
'Tis a bit ironic that isn't it??!! Pity the courier didn't follow that bit of advice!! Roll eyes
Billydakid
PMSL.
Nice one, that was good!!!
oliverb
Which router are you running, if it's a SAR110 would that be firmware 1.37 or 1.38?
Billydakid
I would presume 1.37 (or whatever its shipped with). Not bothering to update it as it seems to be working fine for the mo. I'll look into updating that a later date.
