Stale session problem?
stonechat
Yesterday we had no connectivity, despite the connect light on the router being on solidly.
I cured it by restarting the router.
I read about an issue with stales sessions - perhaps my problem was due to that?
First time I've had any such problem, at least i was easy to fix!
Bob
Happened to me earlier today. It just..stopped working. Restarted the router and it was fine. For some reason though when I goto sites like theregister.co.uk [which have adverts on them] it tries to connect to the ad sites [doubleclick.net in this case] and doesn't load the page for aaaages until eventually it gives up connecting to doubleclick.net and THEN loads the rest of the page.
Sorry..sort of off-topic but not worth of it's own topic Smiley
stonechat
Restarting router
HI
This happened again when I started up this morning - solid light on router, but had to restart it before connection was available
What's going on?
Bob
Stale sessions do not reset with a simple reboot.
It takes a minimum of 30 mins before the exchange will drop the tunnel for your connection.
If a reboot quickly fixes an issue, it would sugest another problem is apparent.
What if any status does your equipment show? (apart from the light)
