Stable speed
ForeverArsenal
Stable speed
Hi
Is it normal for my adsl stable line speed to keep changing every week or so?.
Some times say's stable speed 2000 kbps and I get approx 1950
download,few/several days later will say stable rate 2500 kbps and get download of (now tonight) 2464 kbps.
Any one ?
Many thanks
Barry. :?
Stable speed
It depend what speed you connect at after 3 days its updated. With the weather etc a slight change is normal
ForeverArsenal
Stable speed
Hi mwright
Many thanks for the reply.
I did not know that it changes automatically,thought BT or+NET had a finger in the pie.
Most times I am connected between 3250 kbps TO 3700 kbps but
never get any better download speed than 2500kbps :?
[Moderator's note by James - (sallyandjames): Full quote of preceding post removed as per the link:rules]
cranwin
Stable speed
Think yourself lucky my speeds are changing by the second are these speed tests anywhere near normalHuh?
13-12-2006 15:53:53 2630.4
13-12-2006 15:53:33 896.7
13-12-2006 15:53:06 1938.6
13-12-2006 15:52:44 5090.3
13-12-2006 15:36:58 1773.3
13-12-2006 15:36:28 3276.8
13-12-2006 15:36:07 4443.3
13-12-2006 15:35:47 1937.5
13-12-2006 15:05:25 1462.5
13-12-2006 15:04:11 3945.4
13-12-2006 15:03:52 3474.9
Thought not!!!!!!
Stable speed
Is that the Plusnet speedtest? if so forget it..it doesn't work. Why they don't remove it from the site ill never know.
cranwin
Stable speed
Yes it was the PN speedtest but to be honest I get very similar results from the BT one as well, its just a bit more difficult to paste the results of several tests into a post.
However if I do the "BT wholsale line test" it comes up the same at around 6000 Kbps every time so I know its not my line or the exchange but PN just keep sending me messages saying they are monitoring the fault..... HA!
