Spreadsheet to Track Broadband Usage
Presently PlusNet do not provide an easy means of tracking your Bandwidth Usage against your account limit - and as a new user I needed to have some idea of what rate my allowance was being used - without frequently resorting to my calculator.
To meet this need I have designed a spreadsheet - which additionally:
    predicts likely usage - based on existing use so far for current period;
    calculates the maximum average daily usage to keep within the account limit - based on remaining time and BW.
Forum posts indicate I am not alone with this requirement - so I have made this Excell2000 spreadsheet available for download - on an "as is" basis.
The design is such that usage for successive months can be included for future reference.
To download (25kb) - goto the private page - http://www.goodconnexions.plus.com/usage/broadband_usage_excell2000.html - (private in-as-much that this is the only link).
I hope you find it useful
James
Hi
Have just downloaded your spreadsheet, will give it a test. Could be very handy for keeping a up to date record of total monthly usage Cool
In view of the high number of people voting the original spreadsheet too cumbersom - I've added a much simplified version just to track of current usage with overusage prediction - but without the abilty to store historical records.
This is also available via the link on my original post.
Although with the current VMU problems its all a bit fraught.
James
Hi James
Thought the sp/sheet was ok, although I did one or two mods myself, but if you have updated it I will have another look.
Yes this VMU is causing a real problem for some +net members, but as I have indicated in previous posts, mine seems to be ok, its only the "summary of previous months" that seems to be wrong, why I don't know
