Sporadic Latency Issues
I've had a look around and seen that many people are experiencing some kind of loss of sync problem. This may be the same thing that I'm having, but I honestly don't know. My router doesn't seem particularly inclined to tell me..
Basically every few minutes I get a 10-30 second period of zero traffic. The gaps between the drops are anywhere between 5 and 15 minutes, but I can sometimes go for hours and hours on end without a problem. I don't get any notice onscreen, so I don't know when exactly they occur. I only really notice them when I'm gaming online or manage to request a webpage during the drop.
I say "drop", but the "connected" LED remains lit on my router (Netgear DG834G) and the router logs don't seem to indicate any kind of reconnection:
Sun, 2002-09-08 12:00:16 - Initialize LCP.
Sun, 2002-09-08 12:00:16 - LCP is allowed to come up.
Sun, 2002-09-08 12:00:18 - CHAP authentication success
Sun, 2002-09-08 12:04:41 - Send out NTP request to time-g.netgear.com
Fri, 2004-11-19 16:41:34 - Receive NTP Reply from time-g.netgear.com
Fri, 2004-11-19 16:36:53 - Router start up
Friday afternoon was when I rebooted it (via unplugging it from the mains) in an attempt to solve this lag issue.
I just pinged a random PlusNet server for a good 10-15 minutes (using the -t switch..) and, amongst all the normal ping replies (average reply was 46ms), I had these nasties:
Reply from 212.159.11.150: bytes=32 time=31ms TTL=249
Request timed out.
Request timed out.
Reply from 212.159.11.150: bytes=32 time=39ms TTL=249
Reply from 212.159.11.150: bytes=32 time=48ms TTL=249
Request timed out.
Request timed out.
Request timed out.
Reply from 212.159.11.150: bytes=32 time=29ms TTL=249
Reply from 212.159.11.150: bytes=32 time=45ms TTL=249
Request timed out.
Request timed out.
Request timed out.
Reply from 212.159.11.150: bytes=32 time=42ms TTL=249
Request timed out.
Request timed out.
Reply from 212.159.11.150: bytes=32 time=43ms TTL=249
It's not too much of an issue, since I don't actually get disconnected as such, but sometimes applications (MSN Messenger especially) can interpret the temporary lack of transfer as a disconnect.
2nd hop on a tracert, since apparently knowing the telehouse I'm connected to is useful...
  2    43 ms    24 ms    25 ms  lo0.plusnet.pth-ag1.plus.net [195.166.128.11]
Hi Andrew,
Not sure if you have seen the thread here http://portal.plus.net/central/forums/viewtopic.php?t=22688
It may be related.
As you may read in that thread, I hope to try and collate any similar issues on Monday and see if there is a link.
If you continue to experience this i would be grateful for an update.
Regards
Mark
I really wish it was just web browsing that has issues, but it's everything. As I said it's more noticable on my games (Neverwinter nights being my preference).
hall2295 seems to be having the same problem as I am, though, assuming the Halo 2 disconnects are just the product of a rather short timeout..
I may have the same problem as you do, but mine isn't confined to browsing web sites Wink
stewarta13wsb
I think my 'another 1mb problem' further down the page is the same as this! Wish I knew the answer for you Cry
212.159.11.150 is an OLD DNS server which is being decommissioned so should not be used for any testing. If you have manually setup to use 11.150 & 13.150 for your DNS servers you should change it to 212.159.6.9 & 6.10.
Try your same pings to one of those.
No, I just randomly typed 'ns1.plus.net' while thinking of a server to ping that wouldn't be affected by general internet issues... nslookup is using pth-cdns01.plus.net (212.159.13.49), with .50 being secondary..
Edit:
Still getting them:
Reply from 212.159.6.9: bytes=32 time=53ms TTL=60
Request timed out.
Request timed out.
Reply from 212.159.6.9: bytes=32 time=55ms TTL=60
Reply from 212.159.6.9: bytes=32 time=36ms TTL=60
Request timed out.
Request timed out.
I'm only doing this ping thing to illustrate my point, anyway.
I'm having the exact same problems
I re-sell for plus.net and 18 other customers are having the exact same problems.
When streaming music it effects it more, drops are about every few mins..
lad 2 doors away from me he's using freeserve and its sweet as a nut, and its been like this for nearly a week now
Sad
I am having the long latency issue 2% of pings timeout and also a router sync problem. The sync problem only happens when the router Netgear DG814 idle times out. Re-sync takes 1-2 mins (I know this is too long as it is instantaneous if I reset the router)
