Speedtouch Modem Stats Problem
I have a a Speedtouch Modem aka The Frog and recently I have been having a problem . Every couple of days I get an error message which reads thus :....
Application Error
System Error:
failed To Load resource String ( Oxld)
O.K.
This error messge repeats itslef over and over on the screen and the only way to get rid of it is by CTRL/ALT/DEL and kill it from there . It sems to be rlated to Speedtoch Statistics but I can't see any way to do anything about it otherwise .
Anyone any ideas Huh
Stuart
Have you tried upgrading the drivers. Try http://www.speedtouchdsl.com/support.htm or if you get an error installing the upgrade, download the full drivers from http://www.speedtouch.co.uk/upgrade.asp#330
Thx for the link Peter .
Dunno why i didn't think of that .
:lol:
I've downloaded the upgrade and we will see if that solveds the rpoblem
Well,it hasnt happened since updating the drivers so hopefully thats it done and dusted .thx again
Stuart
