Speeds...again
Speeds...again
For the past 36+ hours since PN changed my stable rate to 8000, my speeds now drop as low as 674kbps just done another speedtest...
Downstream 1,518.2 Kbps( = 1.5 Mbps )
Upstream 355.9 Kbps ( = 0.3 Mbps )
My Router stats are as followed...
ADSL Link Downstream Upstream
Connection Speed 6432 kbps 448 kbps
Line Attenuation 29.5 db 18.0 db
Noise Margin 8.9 db 21.0 db
But I have noticed when doing speedtests or trying to load up games on www.pogo.com my lights on my router are blinking 100 times faster than normal and page's are timing out. I seem to be able to hear the light's blinking (strange I know).....could the up in stable rate be causing these low speeds and erratic router behaviour, or is this just down to the low speeds? I have had no disconnection's though, not even had 1 since I went MAX'ed 2 1/2 weeks ago.(I'm not moaning about that though..lol)
BTW my IP profile is still set at 4500.
thanks hope you can help!
1 REPLY
Speeds...again
This is beginning to really annoy me now, my latest info....
Downstream 419.9 Kbps ( = 0.4 Mbps )
Upstream 344.9 Kbps ( = 0.3 Mbps )
Router Stats including sync rate..
Connection Speed 5632 kbps 448 kbps
Line Attenuation 30.0 db 18.0 db
Noise Margin 7.0 db 22.0 db
Pings.....
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Julie & Jim>ping www.google.co.uk
Pinging www.l.google.com [66.102.9.147] with 32 bytes of data:
Reply from 66.102.9.147: bytes=32 time=45ms TTL=242
Reply from 66.102.9.147: bytes=32 time=38ms TTL=242
Reply from 66.102.9.147: bytes=32 time=37ms TTL=242
Reply from 66.102.9.147: bytes=32 time=473ms TTL=242
Ping statistics for 66.102.9.147:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 37ms, Maximum = 473ms, Average = 148ms
C:\Documents and Settings\Julie & Jim>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.224.116] with 32 bytes of data:
Reply from 212.58.224.116: bytes=32 time=29ms TTL=249
Reply from 212.58.224.116: bytes=32 time=26ms TTL=249
Reply from 212.58.224.116: bytes=32 time=23ms TTL=249
Reply from 212.58.224.116: bytes=32 time=82ms TTL=249
Ping statistics for 212.58.224.116:
Minimum = 23ms, Maximum = 82ms, Average = 40ms
