Speedchecker Reading 0
Hi
Can anyone explain this, speed checks carried out using +net speed checker tonight
Date Speed Achieved (kbps)
25-08-2004 20:33:30 0
25-08-2004 20:33:21 0
25-08-2004 20:33:13 0
The connection must be working, cause i'm logged on :?:
[Moderator's note (by Chris P.): Title altered to be more descriptive of the problem]
Looks like the PlusNet speed checker is kaput Sad
It happens sometimes and others have reported it doing the same in the past but the reason remains unknown (to me anyway). Often waiting a while and trying again it works.
Are you using the https or http URL version. Try the other and see if it works.
Hi
Thanks for the replies, has happened before.
Yes I've waited a while and tried again, and its OK.
Just thought it may be something to do with the pending portal upgrade/change for the new price structure
No, that's happeing mid-day tomorrow according to the latest service status.
I have had zero speed ratings before as well. Not sure why either, but I've gone back later and it's been ok after.
Aaron
Plusnet Staff
Plusnet Staff
The one thing I know that can definately cause zero results is a firewall, although this doesn't appear to be the cause in all situations and there is something else, we just haven't been able to replicate it.
Hi
Have just tried speedchecker again, works ok, reading showing as they should.
using https version, firewall settings still same as last night.
Cheers
