Speed
Speed
Hi, today I test out at 812.10kbps which means I can download at 101.51KB/sec from our servers, my router says thisADSL Link Speed 288 kbps ADSL Link Speed 2272 kbps
SNR 27 db
SNR 17.0 db
No management is currently on my system and I should be on a 2mb connection. It looks to me if there might be issues with my SNR Anything obvious?
Lyn
Speed
I think a lot of people are experiencing slow speeds on http today.
Its taking a lot longer to load pages, seems to hang for a few seconds and then slowly loads.
I'm not being managed either.
Speed
Hi and thx for your reply, the speed actually went back up again after performing the fault tests, however the snr stayed at 17db. This morning I'm getting SNR 28 db SNR 26.5db, what I'm wondering is if there might some intermittened issue with my line?
ChrisC
