Speed upgrade query
iPaqowner
Speed upgrade query
I received an email from PN with the subject heading of "Up to 8Mb broadband speed upgrade" last Friday.
So at last I'm going to get the broadband ADSL Max upgrade.
I'm currently getting downloads averaging 80-100k/sec so hoping to see an improvement and a continuation of stability on the line with PN I've had since broadband started.
Just wondering how long after getting the email advising of my upgrade does the work actually start and will they send another email to tell me it's been done?
Thanks.
1 REPLY
Alecto
Speed upgrade query
The consensus seems to be that it will take an unknown time, and it may be soon or it may not.
You are unlikely to get confirmation that it has been done, so keep checking the sync rate on your router.modem. When the upstream rate syncs at 448k, then you are on Max.
